Results 1 to 6 of 6
Thread: 03 Silverado Security light
    Tuner in Training Mods89's Avatar
    Dec 2014
    16
    I did research and couldn't find a hard answer. I have a friend with a 2003 Silverado and the security light is on and wont start. I understand that the BCM receives the information from the ignition and sends a password to the PCM to start. If I turn vats off in the PCM, will it start? Will I still get a security light on the dash? I'm assuming I will.
    00 Trans Am: Forged Iron Block 370ci, LS3 heads and intake, LS3 Polluter cam, LS7 lifters, FAST 92mm Throttle Body, Long Tubes with Off Road Y, Magnamouth Cat Back, SLP Lid, Viking Front Coil Overs, Rear 3 Way Drag Shocks
    13,565
    Has he tried a security relearn?? I think they have a procedure you can look up.
    But otherwise yeah, you could just disable the security feature in the tune and it "should" start and the light should be off because it's disabled.
    Jan 2008
    399
    Put truck on a battery charger.
    Turn key on and try to start truck. When it dies, let it sit with the key in the on position for 10 mins or until the security light goes out.
    Do it three times and Voila! Truck will run no problemo. Also works if you have to get a new ignition switch or key.
    Dec 2014
    16
    Im aware of the security learn, thats not fixing it. The problem is in the ignition. I just want to make sure the security light will not be on, the BCM controls that. I know we can only program the PCM or TCM with HP tuners.
    Advanced Tuner Road's Avatar
    Dec 2014
    Terrell Tx
    478
    Quote Originally Posted by Mods89 View Post
    The light should go off when you disable it
    Dec 2014
    16
    Awesome, thanks! Im going to do it tonight.
