I'm wondering if anyone else has experienced an issue similar to this. I'm
working on a supercharged 2015 Silverado 6.2 A8 and I have the MAF failed, the
CEL is on at startup and the code shows up. One startup (drive home last night)
everything works fine other than MAP will not go over 97 kPa and TPS won't go
over 50% or so.
The next startup (this morning) the CEL is still on and the code is showing to be
present, however now it will go well over 97 kPa and the TPS will go to 84%
and everything else seems to be working correctly other than now the intake
cam stays at 0 all the time, no movement at all, no codes etc... I cleared the
codes and disconnected/reconnected the logger and now it's back to the way
it was last night for the drive home.
WTF???
