Hello everyone,
This is my first post on this forum and look forward to learning to tune my 2000 LQ4 swapped WS6.
So, i bought HP Pro and an AEM 30-4110 wideband on amazon. I hooked up the wideband and it seems to work just fine at idle. It reads really steady 14.5 - 14.9 or so moving around a little bit here and there. However, when driving around it jumps around from 13.8 to 15.1 or so. The little guage light looks like a fast moving ping pong ball bouncing back and forth between these values. It never stays steady at all when driving around.
Also, when I plug in the wideband to the HP pro box, the readings are just as erratic but at a much faster rate. It looks like an earthquake reading on a seismograph.
Ive done searches and havent been able to find much. The wideband is screwed into a bung on the header collector and the ground is screwed on a metal bracket under the dash/steering wheel.
What is causing this? Any thoughts?
