On my 2013 Buick Regal Turbo, the oil pressure is controlled by the computer but when I plug a scanner into the OBD2 port, the oil pressure is shown as zero. When I check oil pressure with a mechanical gauge, it's quite high, over 100 psi at high rpm. The sensor seems to be just a 1 wire sensor and I assume that it's resistance changes as oil pressure changes, but grounding it out makes no difference. I can't find a pin on the ECM that is supposed to be for oil control, does anybody have any ideas?
