Results 1 to 4 of 4
Thread: i need lots of help
    Mar 2016
    mitchell sd
    2
    i need lots of help
    2007 impala ss (5.3 V8) trick flow cam .595 lift, dual valve springs, 1.7 rocker rollers, cold air intake, magnaflow mufflers, ngk iridium spark plugs, ported heads, comp lifters,
    the car wont idle smells like it is burning rich but afr is reading 14.86
    13,559
    Can't really help you without more information.
    Do you have logs or even the tune for us to view?
    What have you done so far tuning wise to fix the issue.
    It's going to need "alot" of tuning work with all the changes you made. Everything from idle tuning, to changing the whole VE and MAF tables, then working on everything else from there.
    Mar 2016
    mitchell sd
    2
    ok so for starters have to keep foot on the gas pedal to try and keep it running before it dies when we managed to get it up to temp it was a little easier to keep it running but when you let off the gas it would still die so upped the idle to 1100 and that kinda worked but i still dont think it was enough because it still dies, very rough idle when trying to keep it running but i think i have to do a throttle body relearn
    Tuner in Training 1266318172's Avatar
    Oct 2015
    Florida
    11
    Try increasing the airflow final min by about 15% and run it in open loop, set afr to hit 14.7 and disable LTFT. Can't do much without a log file.
