Results 1 to 4 of 4
Thread: Which COM port for Innovate SP2 channel?
    Sep 2015
    26
    VCM Scanner 3.0.53 is what I'm currently running.
    So I don't see a way to select the COM port for the serial channel for the Innovate SP2. Is it set to a specific port already ie. COM3 or is it configurable in some file? I've done some searching through the directories and couldn't find a config file to even look for it. Also I don't see anything in the VCM Scanner to set the com port.
    On the subject I know using the USB protocol that is native on the LM-1/LM-2 was in the works to feed into VCM Scanner. Any update on the progress on that? I can definitely test that out at home if any testers are needed.
    Thank you.
    Sep 2002
    Chicago, IL
    6,395
    doesn't matter, scanner will search for it.
    We got this guy Not Sure, ...
    Sep 2015
    12
    on the same topic. i connected my LM-2 with serial to usb i just got. it showed on the channel list but dosent read correct. it gives a 3 digit number something around 500. but noticed when i shut the engine off and the LM2 screen shows 18 i got the same on the scanner.
    analog thru MPVI works fine by the way
    scanner 3.0
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    A few people have reported issues and have sent in widebands for HPT to try to get it working correctly
