What are you guys doing to tune 96-97 L31 style black box ecm's. I have a request to tune a 96 Tahoe. I have not tried to get a read yet on it but very doubtful I will be able to read it. Can you use a 98-00 ecm in a 96 model? Thanks
They are likely swapping in a newer 98+ ecm.
Thanks I checked and the pin out is almost the same that's what I am going to do.
If you are going that route I would suggest going the whole way and using a 0411 PCM. That gives you even more options.
At least look into before making the decision. Search google for 0411 swap, you'll come across the name Lextech a lot and for good reason, he has a lot of good info and can provide everything you need to do the swap for under $200...
Myself, I am doing the swap on my 98 suburban this weekend.
Update:
I did mine over the weekend and I couldn't be happier. It seems to have made a huge improvement, and the tuning options are wide open... Highly recomend
I swapped in a 0411pcm. Better tuning options, and faster pcm
