Results 1 to 8 of 8
Thread: Injector upgrade, 95% duty cycle LS3 injectors.
    Apr 2010
    4
    I believe I have exceeded safe duty cycle for my stock ls3 injectors (95% dc). I am planning on stepping up to 408ci very soon. Previous combo was a 370ci. Using a truck pcm.
    My question is...
    What is the next step up injector, with injector data that is obtainable? Green tops?
    I don't think I need a set of ID's with my new combo, and I definitely don't want to pay the price. I realize that the ID's are great, and come with injector data, but I just don't think they are needed in my case (not boosted). That is of course I can come up with a solution that doesn't cost as much. Defiantly do not want a "re-drilled" injector.
    I have been searching this forum along with other's but can't seem to find a clear answer. Most people seem to run the LS3's.
    Please help.
    Mar 2010
    Texas Hill Country
    3,299
    I would not go to a Ford injector, they suck at idle.
    stick to a factory GM injector with good data you can pull or go with ID's. Nothing else is worth the hassle.
    Apr 2010
    4
    Quote Originally Posted by Higgs Boson View Post
    Thanks for the reply. Since you recommend a GM injector, what's your opinion on the LS9 injectors? That's the only GM injector that I am aware of that is larger than the LS3. I have seen a lot of debating about the spray pattern difference between the two.
    There's no doubting the ID's, they may be my only option for a larger injector with good data.
    Mar 2014
    McAllen,TX
    160
    I would do some ls9s there around 59 @ 58 psi if i remember right
    Josh Performance Tuning (956)784-0059
    https://www.facebook.com/joshperformancetuning
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    I would check the fuel pressure first, the LS3/LS7 injectors are good for 600 + HP on a non boosted engine
    Russ Kemp
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    ^^This.
    Jaime
    Mar 2014
    McAllen,TX
    160
    also what fuel are you using regular pump gas or e85 ?
    Nov 2009
    All Around
    3,149
    LSA/LS9 injectors
    but stock injectors should make 600HP easy at 58psi
