Dead o2 Sensor?
At idle my B1S1 stays steady around ~500mv with little movement compared to the B2S2. Would this mean a dead o2 sensor? Here is a log file, toward the end you can see the flat spot.
Vehicle is a 2001 Chevy 2500HD with the 6.0 stock tune. Ran standard cfg.
TRUCK LOG.hpl
looks to me like your going to need b2s2 and b1s1. they don't look to be responding correctly. but a for sure test would be to swap sensors if you can and do another log. and see if the readings switch sides before spending 200$
Also, the truck has no driveability issues or codes.
Pull the O2 sensors, shake them and hear if they make some rattling noise, if yes then throw them in the trash or you can do as Brandon said.
