E78 ECU, tuning a Cruze 1.4T. This unknown scale ranges from 0.30 to 1.66 and it is labeled "MAP / Baro (Pressure Ratio)"
What is this actually measure? Parameter?
E67 - 2006 LE5 2.4 Turbo, 444 whp
E78 - 2013 LUV 1.4T
exactly what you typed....its the offset ratio between the map and barometric pressure sensor.
last i remember it was still a custom pid you had to make
PRatio is a built in math in VCM Scanner 3.0
We got this guy Not Sure, ...
I tried some built in pressure ratio parameter initially trying to setup a VE table to log. I just tried it using a custom math function, i can see this output by building a gauge for it, it works.
The problem now (and possibly before) is it wont log data points along the pressure scale see below:
here is the setup for this graph table:
E78 - 2013 LUV 1.4T
I'm not sure when you would want to create your own pressure ratio math, when one is already built in. Try the built in one first.
I found two possible Pressure Ratios I am looking for under Engine > Air Flow > Volumetric Efficiency:
But these two are not outputting any data from these parameters:
Where PRatio Math is the one I created using (MAP divided by Baro)
I can't find these Pressure Ratios under the Add Channel, so these can't be added to the Channels List
E78 - 2013 LUV 1.4T
If you assumed MAP = 100kPa, then PRatio = value x MAP (100). So pretty safe to assume that a value of 0.25 PRatio is ~ 25kPa. Not always true if you're referencing the base MAP as some other value than 100 kPa, but it's a good way to roughly estimate what each label means.
~Erik~
2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
