Results 1 to 7 of 7
Thread: I have an autometer fuel pressure sensor, and can't get support.
    Feb 2006
    Buckingham (Doylestown) PA
    216
    I posted in that gigantic release thread about not seeing support for the Autometer fuel pressure sensor.
    Kevin asked if I could get the data for it, he'd add it to the next release, but I have yet to be able to find anything.
    The thing is, it was supported in 2.24, so I'm sure they have the data in the archives somewhere, it was a select-able option before.
    This is the sensor I'm using, and like I said, it was supported before.
    http://www.autometer.com/100-psi-pre...ransducer.html
    To me, fuel pressure is just as critical to monitor as afr, timing, etc. I log every time I drive, and I want to make sure that fuel pressure is staying where it's at with ~900rwhp.
    Thanks.
    2000 T/A - Thompson Motorsports 416ls3, F1A procharger, HP tuned. Just a couple psi of boost.
    2013 Mercedes C350, wish HPtuners worked.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    It's a 0-100psi sensor on a 0.5-4.5v range. The transfer is as follows:
    Pressure = V * 25 - 12.5
    http://www.dsxtuning.com
    Just say no to bull s***.
    Dec 2008
    on the Dyno
    1,825
    Just use the AEM 100psi sensor built into the scanner. It's the same sensor.
    Located in Central Kentucky
    ShorTuning
    Sep 2002
    Chicago, IL
    6,395
    I believe the transform you want is already in the software, under Pressure Sensors->AEM: AEM (PN 30-2130-100) 100 PSIg
    We got this guy Not Sure, ...
    Feb 2006
    216
    Thanks for the replies guys. I'll try the AEM sensor and do some data logs and see if they are comparable to what it was previously... it should be.
    Nov 2010
    Finland
    249
    To the same pressure measuring question: I get that formula "Pressure = V * 25 - 12.5" put into scanner V3.2 by putting "(1/25)-12.5" to the equation but how do I ad "*0.0689475729" to it since I need that to transform psi to bar.
    It seems it's always a must to choose a parameter when adding a channel. This choosing a predefined parameter retrieves a name to the parameter list that I would like to change but I can't.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    You don't have to. Use the correct formula for PSI and chose a unit of PSI when setting up the transform.
    Then when you're using that fuel pressure parameter in charts/graphs/gauges there will be a box for what unit you want to use. Select bar or whichever unit you prefer and it will do the conversion for you
    Or you can just multiply the whole psi formula by 0.0689 to convert it over to bar that way.
    I think the former is easier.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
