Initial Tune - Holden VY (L98)
Hey guys,
I was wondering if anyone could help me with a few steps in setting up a Holden VY LS1 PCM to work with a L98 Engine.
I have already sorted out the Crank Reluctor (Pressed on a 24x Unit) and the Cam Sensor (used a Cam gear with a 180* Moon shaped ridge)
Car has:
Holley High Ram
Custom Turbo setup w/ 42R
2.5 BAR Map Sensor (Also have a Delphi 3 bar block style)
1000cc Injectors
Basically I have tried to use the 2Bar Patch but with no avail, VCM Scanner keeps saying the max MAP is 105.
I setup the file, turn the key, it fires to life then shuts down with no codes.
Just waiting for the laptop to boot so i can attach the base tune.
Thanks,
Nathan
Here is the base tune I have written for the car.
Is there any changes I should make?
Are you using VCM 3.0 ? I cant open tune
