Results 1 to 16 of 16
Thread: #52 injector table
    Dec 2005
    Sweden
    267
    #52 injector table
    I need the injector table for a size 52 injector...
    #52 DELPHI 17113738
    Static Flow Rate: 50.0 lb/hr @ 43.5PSI (300kPa) 525cc/min or 6.4gm/sec
    Static Flow Rate: 57.7 lb/hr @ 58.0PSI (400kPa) 606cc/min or 7.4gm/sec
    Dynamic Flow Rate: 1.1 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 43.5PSI (300KPa)
    Dynamic Flow Rate: 1.3 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 58.0PSI (400KPa)
    Coil Resistance: 12 Ohms / High Impedance / High-Z (No ECM driver modifications required)
    Cone Spray Angle - 22.4 degrees - single spray cone. Approximate cone angle for 90% of spray volume
    Ball/Seat Design with 6-Hole Diffuser Disc
    Big thanks.
    Black Pontiac Trans Am WS.7- Runs on E85
    And soon to be powered by Twin Turbos.
    How to run your LS1 on E85
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Look Here for the spread sheet.
    But here is what you want.
    If you have a return fuel system you just need the frirst value copied to all cells.
    Code:
    57.7360451 58.09587365 58.4534872 58.80892616 59.16222974 59.51343595 59.86258171 60.20970288 60.55483425 60.89800967 61.23926202 61.57862327 61.91612452 62.25179601 62.58566719 62.91776671 63.24812249
    EC
    Always Support Our Troops!
    Dec 2005
    Sweden
    267
    Thanks.
    Dec 2005
    Sweden
    267
    I tried the table and the car wouldn´t even start until i added 25units to the VE-table. And it also made my idle go up 100rpm (maybe it settles later?)
    Apr 2003
    Almost 2000 feet.
    7,876
    The table is correct for the injectors you specified.
    I'm not surprised that the VE table moved on you though. Probably the old injector and flowrate in your calibration was off.
    EC
    Dec 2005
    Sweden
    267
    now that i have raised my VE by 25, should i change my cranking VE aswell?
    Apr 2003
    Almost 2000 feet.
    7,876
    If the car starts right up, no.
    If you have long crank times with no fire yes.
    If the car starts and then acts up it's a different table:
    Fuel Control.General FA Mult Stage 1 vs Time
    Dec 2005
    Sweden
    267
    Quote Originally Posted by EC_Tune
    Yes, It doesn´t start right away... and when it does it idles rough and when i touch the gas it almost dies
    Any help would be nice
    Apr 2003
    Almost 2000 feet.
    7,876
    Are you logging your STIT & LTIT in gear & LTIT Pk/neutral (Airflow trims, not fuel )
    If they are going very positive, thats part of the problem. I log in g/sec but you can do it in lbs/hr if you wish.
    Here's a Thread on logging STIT & LTIT.
    EC
    Dec 2005
    Sweden
    267
    No i havent logged STIT....
    Should i change my cranking VE back to stock?
    I should log from cold to hot, right? with gear and without gear? more than one time? reset fuel trims?
    I can use the included histogram from the scanner, named idle desired airflow ?
    Dec 2005
    Sweden
    267
    I cant get it to work the way i want...
    Cant you make two histograms(using ltit and stit), one in gear and one in neutral... for idiots like me
    Apr 2003
    Almost 2000 feet.
    7,876
    Just dropped these in on your other POST
    EC
    Dec 2005
    Sweden
    267
    Thanks.. EC
    Jul 2005
    arkansas
    530
    i have these same injectors. did you get them to idle right? mines shows way lean. once got a missfire cel. i need help on these.
    '04 Tahoe AWD, trickperformance turbo kit, TC78 turbo, 4"magnaflow muffler, Circle D triple disc 3,000, FLT LVL 7 4L60E, L92, 227/235 111lsa.
    Old 5.3=12.33 @110mph
    http://www.streetfire.net/video/turb...mph_741849.htm
    Dec 2005
    Sweden
    267
    Quote Originally Posted by 4.8t
    No, i changed injectors...
    Jul 2005
    arkansas
    530
    i think i want a refund. this plum sucks.
