Results 1 to 12 of 12
Thread: Having issues installing RaceRender on MacBook
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    I am trying to install RaceRender on my MacBook pro and am having issues. It seems to go through the install process properly and I found a folder in Documents called RaceRender 3, but I can't find a program that I can run.. I rebooted and tried reinstalling to the same result. There's nothing added to the apps folder or anything else that I can find via search that I can open.
    Am I missing something totally obvious?
    I'm running El Capitan 10.11.4
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    HPT Employee Weston@HPTuners's Avatar
    Jul 2014
    39.735034, -103.894459
    868
    There has been an intermittent issue with the Mac installer that affect some systems, but it's often resolved by trying the installer again or rebooting.
    Failing that, a quick solution is to download RaceRender as a zip archive from here: http://RaceRender.com/RR3/RaceRender332.zip
    The included "Read Me" file gives installation instructions, and it's pretty simple for Mac. This approach has resolved the installation problems for everyone else who reported these issues.
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    I will try that now and report back
    I'm loving the software.. I played with it in Windows on VMware a bit earlier. I might even break down and buy the higher end one
    Do mods get free software?
    I had some trouble getting VCM Scanner V3 export logs to work properly.. I had to go through and change the format a little bit. Is this a known issue since the recent release of V3 or no?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    It is now running in OS X, thanks
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    I went ahead and purchased the paid version. It's such a neat program.. I'm still getting used to it but it should do exactly what I want it to do!
    Jul 2014
    868
    Glad to hear it! Yes, the CSV output from VCM Scanner recently changed a bit with 3.0. The very next update to RaceRender (v 3.3.4) will work with it directly.
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Is that coming relatively soon or will it be a while?
    One other question:
    Is there any reason I can't record with the camera on my phone while the phone is also starting/stopping a GoPro for video, then I'd use a log from VCM Scanner for data? GoPro hasn't arrived yet so I haven't been able to just try it.
    I'm doing a 1/2 mile event in a few weeks so I figured that would be the simplest/cheapest way to get two camera angles and still be able to use Scanner at the same time during runs..
    Jul 2014
    868
    Just released it a few minutes ago... http://RaceRender.com/RR3/Download.html
    Manual-install .ZIP package: http://RaceRender.com/RR3/RaceRender334.zip
    One other question:
    You could use TrackAddict to do this... It's able to record video from the phone and with a GoPro (controlled via WiFi) at the same time, and they'll be pretty closely synchronized to each other (it sometimes warrants some fine-tuning in RaceRender, but that will get you close to start with).
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Good deal. I bought that one already too I made a quick video last night and it really came out neat just using an ELM327 interface + my phone. I had to go in and manually create a "boost" column from the MAP sensor data and then put that in a chart but once I figured out how everything worked it worked well.
    Thanks, I'll download the latest.. that will make it easier to use logs straight out of VCM Scanner
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Do you have a .zip link for the latest 3.35a version? I tried using the installer again but it didn't work, same problem as before
    Jul 2014
    868
    Yes, the updated ZIP is here: http://RaceRender.com/RR3/RaceRender335a.zip
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
