Results 1 to 18 of 18
Thread: Setup LC-2 to read as Lambda Scanner 3.0
    Advanced Tuner jpb1972's Avatar
    Mar 2015
    New Jersey
    271
    I'm trying to setup my lc-2 to read as lambda. I figured out how to get it to display AFR on the Channels list, but that's as far as I'm getting. Can't figure out how to get Lambda to display on my "Chart vs. Time". Any help would be appreciated.
    (My LC-2 in connected through my MPVI)
    I know my config is a mess, but I'm still figuring stuff out.
    Sep 2002
    Chicago, IL
    6,395
    We don't have a built in LC-1 or LC-2 lambda transform yet. Do you have a link to the default scalars?
    Also, with the innovate LC products, you can adjust the output, which is best to minimize voltage offsets.
    We got this guy Not Sure, ...
    Sep 2002
    Chicago, IL
    6,395
    I've added it to tomorrows 3.0, where 0v = .5 lambda and 5v = 1.5 lambda
    Mar 2015
    New Jersey
    271
    Awesome. Thanks!
    So there's no way for the end user to set up user configs like 2.24?
    Mar 2015
    New Jersey
    271
    OK, thus far I selected the new Lambda transform for the LC-2. In my channels list it is showing AFR still. Do I have to record a new log for this to work right? There are several pieces to this puzzle I'm sure I'm not getting.
    Are there new help files for 3.0 that I can refer to?
    Sep 2002
    Chicago, IL
    6,395
    You probably selected the LC-1 under Air/Fuel ratio group, not Lambda group.
    Mar 2015
    New Jersey
    271
    That was the first thing I checked. That's why I'm wandering if I have to do a new log for it to display properly. But no, the LC-2 under Lambda group in Oxygen Sensors was selected.
    Sep 2002
    Chicago, IL
    6,395
    yes, you must transform the LC-2 using the EQ ratio (lambda) transform, it's different than the lc-2 afr transform.
    Don't forget you also need to connect to the LC-2 with their config app to change the default output from afr to lambda.
    Mar 2015
    New Jersey
    271
    The settings were already done, as it was working with 2.24.
    Sep 2002
    Chicago, IL
    6,395
    2.24 did not have built LC-1 or LC-2 eq ratio (lambda) transforms, only air/fuel ratio.
    Mar 2015
    New Jersey
    271
    I understand that. I was able to make it work through custom pid. Whatever it was, it worked.
    Mar 2015
    New Jersey
    271
    Quote Originally Posted by jpb1972 View Post
    UPDATE: Connected to the car, uploaded config to the MPVI and it seems to work. For some reason it (my WB lambda) froze. Once I stopped the scan and restarted it the lambda reading began to work again.
    Any ideas?
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Any ideas?
    There is an ongoing issue with external inputs freezing up. The cause has not yet been determined (as far as I know anyways). There's a big thread about it in this section where several people are trying to narrow down what is causing it
    Mar 2015
    New Jersey
    271
    I did see this. I've been scouring the 3.0 New Release thread.
    Thanks for the reply.
    Feb 2006
    central michigan
    349
    is there a secret handshake to get a lamda transform for the afx-ngk ?
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    The transform for that WB in lambda is included in Scanner. Update to latest if you aren't already using it.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Feb 2006
    central michigan
    349
    thanks---brain farts happen with us old guys.
    Please add the MTX-L to this as well.
    '15 Colorado Z71 | '07 TrailBlazer SS | '87 Monte Carlo SS | '80 Lemans Wagon
