Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 98
Thread: How many of you experienced code P1516?
  1. #21
    Aug 2005
    Texas
    115
    I have ran into several times with boosted LS3's, and also with NW TB's in E38 ecms mostly. I didnt have a way to fix it with hpt but was able to fix it with another software and a third party program. It would be very nice if HPT would add the table in.
  2. #22
    Jan 2009
    21
    I actually have a 2008 silverado 5.3 doing this with a stock tb....just did a DOD delete and thats all. Does it if power braked to WOT.
  3. #23
    Sep 2007
    23
    Quote Originally Posted by Engineer@HPT View Post
    I've responded with a solution to everyone with an E38/E67 who has contacted me.
    I just emailed support again. I set the positive and negative values to their max thresholds and flashed a write entire to the customers car. P1516 came back on during his drive home within 10 miles.
    Justin Stephens
    2007 Z06
  4. #24
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    Here is a 2010 Camaro equipped with a 2.9L Whipple and a NW 102 DBW throttle body. After using the special beta build to eliminate the P1516 test, it does not go into reduced engine power anymore, but it is quite clear to see that the blade is closing on its own. Accelerator pedal is at 100%, and there is not torque management intervention. To me it is obviously a hardware issue in this case.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
  5. #25
    Tuning Addict
    Jan 2015
    6,736
    Have you tried flipping the TB or is it even possible on that setup? The wide blade TB's do catch air like a plane wing and causes them to do that...
    ~Greg Huggins~
  6. #26
    Apr 2006
    Raleigh, NC
    449
    Not really possible to flip the throttle body back over on the Whipple setup.
  7. #27
    I've run into this before as well.... Some were fixed with a NEW gm TB. I'm afraid to try larger TBs assuming that
    the push/pull on the blade would only make the problem happen more frequently. What can we do to fix it?
    Chuck CoW
    Chuck Mosello - CORVETTE DOCTOR
    Corvettes of Westchester
    www.CORVETTES-OF-WESTCHESTER.com
  8. #28
    Dec 2015
    Reno
    63
    I'm at 40% for positive and negative and still having the issue. How much higher should/can I go?
    What is everyone else at?
  9. #29
    HPT Employee Engineer@HPT's Avatar
    Jan 2015
    fecadefa
    615
    Quote Originally Posted by SMEC View Post
    Make sure you write entire every time you make a change to those values. If you already did, then try higher than 40.
  10. #30
    Dec 2015
    Reno
    63
    Yes sir I have, going to go higher.
  11. #31
    I was directed to this thread, im having issues with P2101 and P1516 after doing a LS3 (gold blade) throttle body swap (8 pin to 6 pin) on a LS4 car with a stock 78mm 8 pin "truck throttlebody". It's an 07 E67 ECU, and I have had several wiring diagrams thrown at me with regards to how to wire this thing, which ill attach pictures of. Currently I am using my 5volt ref and Low ref off the TPS1 signal circuit, according to what ive been able to pull up about the LS2 throttle body, HPT is showing the voltages being reversed at WOT. My P1516 and P2101 codes only occur after RELEASING from WOT. Part throttle functions normally, and you can hold WOT as long as you want, but as soon as you release, the throttle blade stutters coming back to a close, even when testing with KOEO. Ive tried two different brand new LS3 throttle bodies with little success on this. From the research that ive done, the P2101 shows a .3 second discrepancy in actual throttle position vs commanded, and P1516 is .5 seconds. I'm wonder is this a wiring issue i am experiencing or a tune issue?
  12. #32
    Quote Originally Posted by avalanche View Post
    Do all of these issues people keep having seem to coincide after going WOT?
  13. #33
    another question for you all, when you get the P1516 code are you getting P2101 as well?
    P1516
    The indicated throttle position does not match the predicted throttle position for more than 0.5 second.
    P2101
    The indicated throttle position does not match the predicted throttle position for more than 0.3 second.
    P2119
    The ECM determines that the throttle blade did not return to the rest position within 720 milliseconds.
    P2176
    The difference between the predicted and the actual throttle position is more than a calibrated amount for more than 1.5 seconds.
  14. #34
    Jul 2007
    49
    We have been having this issue on a procharged ls3 with a stock throttle body right after a wot pull it goes into reduced power and 1516 comes up.
  15. #35
    Just wanted to let everyone know, I received a copy of the beta from support, changed the limits to 40% for P1516 and P2101 and the problem was solved!
  16. #36
    Tuning Addict
    Jan 2015
    6,736
    Which version of the beta are you all getting this in? I've opened up a couple of tunes in 3.1 and don't see any of these changeable limits? Is this like manifold volume and has to be requested?
    ~Greg Huggins~
  17. #37
    I had to send my tune file to them and they sent it back to me modified.
  18. #38
    Mar 2015
    gippsland
    134
    Hi,am having the same issue with 06 ls2 p38 controller, will log P2101 and p1516 at WOT only.
    This has only started to occur after fitting Otr to vehicle, maf is installed and not fouling on butterfly.
    On one occasion checking the throttle body with intake off the assembly seems dead, after a couple of key cycles it will come back to life carrying out self test and setting butterfly to start position.
    I have emailed support with tune file to hopefully get some assistance.
    Will keep on this thread for any news on this issue.
  19. #39
    Quote Originally Posted by tris909 View Post
    If the throttle body itself is acting funny, i would either inspect the connector for faulty wiring (sometimes the copper can be broken inside the rubber insulator, or loose connections at the pin. Or replace the TB entirely.
  20. #40
    Mar 2015
    gippsland
    134
    Wiring seems fine, as well as pins/plug. I thought it may be a faulty throttle body, I will source one to try and see how I go.
