Hi guys. If anybody could figure this out I would really appreciate it. I had a ls7 lifter basket collapse on me about a month ago. So I put in a new set of johnson link bar 2116LSR lifters. The cam is cut on the exact same specs as my old one. Only diff. is the new cam is a cam motions cam on softer lobes for better valvetrain control. The old cam was cut by lunati which has alittle harsher lobes. the cam is a 219/232 .625 .599 109lsa Nothing too radical besides the lsa. I notice that my vacuum is down quite abit. before at idle in park it would hang around 13.3 and in gear foot on brake it would be around 8.8 in hg.
Now at idle in park it's in the low 10's and foot brake in gear it's in the mid 6's. Having alittle hot startup issue, but I have been adding more air at the temps and I believe that is helping that part out. I just for the life of me can't figure out why my vacuum is down. Unless I have timing off one tooth, but the car seems to run great and sounds great. I haven't taken over 3500 rpm's yet. just babying it getting the street tuning down. I know I need to lean it out alittle bit more at idle. And there are no vacuum leaks anywhere. Thanks for any help. I tried upping idle timing 4 to 5 degrees it didn't help.
