I have a 06 with efi on the truck and it won't let me tune, but I can read the file and look at the values. Is this efi file the problem or something else? Any help would be appreciated!
If i was you i would take that question and email it to [email protected] along with your file, the VCM log information and see what they say for supporting this. Quickest turnaround
2005 Cummins 325/600 G56 3.73
Reving to 4800
Worked Head, Twin Disc, BBI
Same thing was happening to me. Make sure your battery connections are tight, and driver side battery is charged. After that try writing again, sometimes it takes me 2 or 3 times to get it to work properly. Make sure you hit your unlock button as well, just to make sure the SKIM isn't flagging it.
Thanks I will try that!
I ran into that on Thursday. Already sent it over to support. Do you have this ECM?
ECM: 7E8, CAN - CM849, Dodge Cummins 5.9L
VIN: xxxxxx - 2006 Dodge Ram 2500, 5.9 L, I6
Serial: 33703
OS: 35325533AM
Calibration IDs: 35325533AM
Calibration VNs: E3991513
Basic PIDs: 25
Pending Trouble Codes:
Trouble Codes:
Controller Type ID By OS: 23012
Diagnostic Requirements: None
Scanning Methods: ISO 15031-5 Mode 0x01 Functional, ISO 15031-5 Mode 0x01 Physical, ISO 14230-3 Mode 0x21, CAN Listener
2003 305/555 QCSB Cummins
Piston/rod/sleeve/fire ring/dual CP3/300 overs
Super Stick NV5600
S366/S480
I can not get my hptuners to read my 07 5.9 truck at all. The read vehicle tab is grayed out. Scanner connects just fine though.
Nevermind. I am reading mine out now. I opened and closed program several times, restarted my computer etc. Just finished read and says invalid checksum.
Just emailed it in. Thanks! Does anybody have a stock 06-07 file I could look at?
If you have a tune open, the read option is grayed out.
Yes that was the issue. I went to File, Exit and then reopened and it allowed me to try to read out my file.
