Results 1 to 15 of 15
Thread: 2009 G8 locked ecu
    Feb 2010
    21
    2009 G8 locked ecu
    Car is stock, customer deleted the Dod but I can't acces the ecu to delete it
    So we got a new ecu from LKQ and went to flash it, it's a 2007 impala v6
    What do I need todo to put a stock g8 file in this ecu and make it run in the car
    I tried uploading a g8 file I had and did write entire but it won't even activate the starter, says engine emobilized.
    Apr 2015
    302
    Sounds like you need to shut off VATS
    Jan 2008
    399
    Turning off VATS is a hack move for hacks.
    Did you plan on changing the VIN to match the customers car? Im sorry, but if you are doing this as a business, friggin do it right or don't do it. I would look past this if it was your own car, but you are charging someone to do this and you can't even set up a PCM to be tuned? Stop now.
    https://www.hptuners.com/help/index....change_vin.htm
    https://www.hptuners.com/help/vcm_ed...elink_vats.htm
    Feb 2010
    21
    Quote Originally Posted by matty b View Post
    I tried changing the vin by it said vehicle validation failed, unlicensed vehicle, I'll get it now, thanks for the help
    Feb 2010
    21
    I can't change the vin, I licensed the new ecu, changed the program, goto change the vin it say vcm validation failed, unlicensed vehicle?
    Were the E38s the same part number?
    Feb 2010
    21
    Quote Originally Posted by SSUte01 View Post
    No
    Jan 2014
    Australia
    1,984
    I'm trying to change ecu at the moment too and get the same thing ive found because the OS is different the bcm dosnt like it and won't link vats or let it start, can't even turn vats off be good if there was a way round it with hp
    Feb 2010
    21
    Just for kicks I tried turning it off too, no luck
    Anyone know what needs to be done to fix this?
    Not all E38s are the same and not all OSs are compatible. It is possible that you've damaged the ECM. What OS did you write entire to the new ECM and what part number was it?
    Jan 2006
    Collinsville IL
    697
    Get the correct PCM and have someone with a MDI flash it.
    https://www.facebook.com/tuningbyshanehinds
    [email protected]
    2009 G8 GT [email protected] 1.60 - Sold
    2008 A6 LS3 C6 Cammed [email protected] 1.44 Sold
    2013 CTSV wagon 9.21@151
    2015 C7Z bolt ons 10.0
    What is the service/part number of the ECM and OS you installed?
    Feb 2010
    21
    I got a new ecu same part number and os as the original ecu from the car
    same issue
    Jan 2006
    Collinsville IL
    697
    You need to flash it with a MDI unit. All the security and key stuff isn't happy.
    [email protected]
    Tuner Doubledip's Avatar
    Apr 2007
    Sydney, Australia
    161
    if its new then the ecu is effectively blank (will have stuff in there but that's only so the flashing tool can write to it) you need to have TIS2WEB files flashed into the new ecu and then have the immobilizer code / linked to the car so it will start
    Ultimate Conversion Wiring
