Wow this thread has gotten some very good advice added, thanks everyone for the contributions!
99 T/A WS6, original LS1 turbo
And I agree it is a great procedure for E40 PCM's, the E38 has a different set of control parameters. I have never tried to mix the 2. I Have used Bills procedure as well on E40 setups. The similarities to the 2 procedures is the use of the Idle adaptive spark values to develop you error correction. In Bills he logs the spark values and uses them as correction data. The idea is the closer you get the airmodel to ruight, the less the spark will have to fight to maintain the desired idle rpm.
In the above, it is done "by eye" as you make the TB blade adjustments for max and then the Min Idle air for the min done by return to idle with a blip and then the proportional and integral to manage in between.
The E40 parameters do have a Max (effective area) which is equal to the TB total area and a Min, which I assume is the absolute lowest effective are you could command, but isnt that in conflict with the Base Running Airflow?
Ed M
[email protected]
2007 Corvette C6 Vert. A6
LME LS402, Pat G custom cam, ATI 10% OD Damper
Circle D triple disc 2600, 3.42 Diff
YSI, 3.0 pulley, ID 1000's
Alky Control Meth,
ARH 1 7/8 headers,
1009 RWHP @ 7000, 817 RWT @ 6000
[email protected]
I've learned I have a lot to learn on idle tuning between seeing Ed's method and the other thread about how the integral/proportional idle adjustments work.. One of these days I'll sit down and read it all
It may just be me, but I've never had any luck at all with maxing out the min airflow table and zeroing out integral and proportional to set the % max and % max brake settings of the TB. I always get way too small of numbers and wind up having to add something like "1 or more" back to the numbers I came up with to fix the cold start and idle dipping issues created by lowering them. Is there a better or even possibly another way at all together to get these numbers? This way does seem to get something plausible for the min air value for the min air idle table, but that's all it seems to do for me...
~Greg Huggins~
Hey Greg, Hope all is well. How did you make out with that shop car project from way back in September? Man can't believe how time flies.....
Not sure about why you need to add so much when done but the key to me is to get all the engine/trans loads to their max as well as functions like idle rpm (at or above the coldest cell), AC on HI, Fans on 100%, if an auto, in gear and on the brake (the extra idle rpm would also put a bit of TC load and even turning the steering wheel all the way (:-) just to get the maximum torque/load for each scenario.
I am open to any better way to go because sometimes these Gen IVs just fall into idle/return to idle and some times they just don't want to cooperate...
Have a good evening and weekend
Ed M
[email protected]
Going to be taking a different all around approach to the shop car... Right now it's on the back burner once again and doesn't look like I'll be able to get back to it for another month or so?
This is how I've started setting the %max and %max brake. Most likely not right, but if I do it how it's written up on the EFI forum I have to almost double the min air table from what "I" think it should be - It will wind up way up in the teens... It's even been mentioned under Mike's post that he had to use really high min air values following the procedure... SO basically I start by first setting the ETC Scaler to what it should roughly be - if not a touch under... At the same time I'll set the proportional and integral tables to a "stock" setting from an OE calibration closely resembling the current engine displacement of what ever I'm working on, such as if it's a 416 build - I use the newest 427 OE settings... After this I "guesstimate" the min air values based on cam and so on additions used, then dial in the MAF and VE table at least through 2000rpms... After this if I haven't all ready gotten the g/s reading, I'll fire the motor up and get the g/s reading from the MAF at the "hot running idle rpm"... I then enter this into the min air table up through 800 rpms and increase slightly from there. At this point I use the bi-directional controls of the scanner to force the engine 100 rpms below commanded. If I can't go that low - I lower the % settings. Same goes for if it goes too low - I raise the settings... Then I use the min air to "dial" things in a little better if need be.
Anyway most likely wrong, but that's how I try to do it...
~Greg Huggins~
[email protected]
