Results 1 to 5 of 5
Thread: 98 3800 Fbody PCM -Unstable idle
    Oct 2014
    Houston TX
    39
    Just looking for some good pointers.Turboed,I run a n* TB. I Maf tuned and the car runs good,Idles good. Maybe 2% off of desired AFR.
    Problem. I rev it up to 3000 rpm or more and the car has a hard time rebounding unless I have the Throttlebody set screw opened up pretty good. But then gives me a real high idle. which is not wanted. The tables on a 98 Are a joke I know. But I want the cable not drive by wire. No way to control the iac ramp. What can be done. ???
    Thanks!!
    13,559
    Can you run a stock L36/L67 throttle body??
    They have less issues than a northstar throttle body that really touchy.
    Oct 2014
    Houston TX
    39
    I run a N* MAF also. Why they so touchy ,so its normal? might be able to switch to a l67. was thinking of a ls1 wouldnt this work? Thankyou
    Advanced Tuner Dr. Nopps's Avatar
    Jan 2011
    I'm proudly a successfull stalker of an honor roll student!
    368
    Please post your tune. I can't view it myself, (laptop crashed) but if we can see the tables you're working with we might be able to describe some tricks that have been used on them in the past, or give you a better picture of what to expect down the road.
    Oct 2014
    Houston TX
    39
    Move the Maf sensor from before the turbo to the up pipe and problem solved. Learned something new.
