I was wondering if any one knows how to run cruise control on an e67 pcm. I know in ls apps it can be ran though the pcm by using the 08 trailblazer flash but can this be done on a lze or lz4 v6. Is there a patch or an interface to replace the bcm
No. Nobody does. You will either need to use a BCM or a dedicated Cruise Control Module. HPT does not do anything regarding BCM functions so if you go that route, you're more less on your own.
