This is what I was trying to better illiterate, but obviously failed miserably the last time
At this rpm level - "I would think or atleast believe that the MAF or VE models alike - if tuned correctly, should correctly fuel the motor" THAT IS if the fueling is maintained and correct. A PD blower due to the instant and tremendous spike in manifold pressure will actually cause a much smaller amount of fuel to be delivered than "requested" if fuel pressure isn't correct - REMEMBER - you have manifold pressure working against fuel pressure - so how does that 38psi of fuel pressure look now? I fought this and fought this on a 18psi PD blower because of fuel pressure being 12psi lower than what it should have been.
Yours is dropping to 38psi with how much boost fighting agains it? - Yikes....
We run the Squash dual in tank fuel pump configuration - does away with the fpcm all together on the camaros. Comes with vacuum and boost referenced regulator that you dial in. Can't put the regulator on the backside of the rails - Goes on the feed side... DO NOT use the supplied fuel line - highly recommend gates high pressure fuel line and use plumbing or automotive style crimp clamps to attach the lines... Other than this - not a bad system...
I'm aparently in the dark - going to look into the C.A.T.S system. Would just be nice if HP had all of this.... Seems simple enough to add?
