Well I finally figured out my Transient Fuel problem. I've read allot and asked allot of people on here, and debated (argued) with some pro tuners about how these settings work, and I came to the conclusion that they must not be workign right on a Manual Trans, Whipple type 2010 E38 LS3 Camaro, and I was right since the settings never worked for me, it usually made it run pig rich and chug down low, and still was lean where I needed it (up high).. and finally have proof why I say these settings don't work right! Years of wonderment finally figured out.
This is a bench setup, I simulate RPM and MAP and other sensors and have to ability to ramp boost up similar to the scenerio's I have this problem in the car.
From Idle through 3999rpm, they do in fact work and I increased transient fueling (by quite a bit to see how it works) simply adding fuel to the Warmup Transient Base Gain which I knew... but at 3999rpm the transients quit completely! I found Evap Factor and had some RPM scale so I maxed all of those out also, and still I get no transient fuel above 3999rpm...
Pic and tune attached. tune is my bench tune so there is allot of stuff that isnt right...
Around 12:04:24 in the log notice the ton of transient added below 3999rpm and how much injector pulse gets added when I transition from low MAP to high MAP... above 3999rpm this goes away completely (this pic is included below).
Can anyone shed some light on why, or how I get Transients working above 4000rpm? This would be HUGE. TO compensate for this I slowed down my THROTTLE OPENING RATE a ton but it still is a bit lean shifting between gears (or going WOT) around 4500-5500rpm due to this major issue...
Transient below 4000rpm.hpl
2016 2-14 Read for MAP Enrich Play Testing 3.hpt
Adding things I found since this original post... will post anything significant here:
EDIT 1: Had more time and found Transient Stops working at precisely 4000-4010rpm, and begins working again right around 3900rpm. So far the Manifold Volume has no impact on this.
EDIT 2: The stock file doesn't have any added transient fuel at all, as stock. With only the Warmup Transient Gain added (no Impact Factor Gains) then the Transients return to working, but still below 4000rpm.
EDIT 3: And of course, the same exact RPM's I see the transients quit working and re-working are the same as the stock Dynamic Airflow Enable/Disable.. as Mowton mentioned below...
Edit 4: Transient FUel "ENABLE Delay" ECM 2287: Looks like it's a delay from Engine start... so ~50, Transients start working pretty quick after engine start. 5000, they pretty much start working ~20 seconds after startup. 10,000 transients start working after about 40 seconds both tested running at 3400rpm. Was really hoping 0 would fix the problem... dang
Edit 5: I played with the Transient Fuel Mass Gain/Gas and Gain settings, all I got was severely increased constant Injector Pulse... no change to the Transient at all.. just more fuel everywhere... and I saw this before... so near stock may be best for these.
EDIT 8-22-2017:
Still trying to figure this out.. .now I see it show up as cut injector pulse when playing with the bench setup and most or all fueling tables set to either 1 or 1000 everywhere (so no change in fuel).
Injector PW gets cut from 8.5ms to 2.9ms, only thing changing is the rpm from 3999 to 4000 (or 4001rpm). It starts to climb back slow (relitively slow) to 8.5ms when RPM crosses 3900rpm.
Wish someone could figure this out! Tune and log attached. Tune is a bench tune, most fueling and spark tables set to constant values to narrow things down.
this is for my transients that just stop working above 4000rpm.. I'm convinced it's a problem at least with my tune or OS. I have looked at other peoples logs and they don't seem to have a problem.
Attachment 72795
Attachment 72796
Attachment 72798
