I plan on going up to the track in the spring time,, working on the trans tune in sport mode the 1-2 2-3 shifts are good but I keep turning up the pressures ,lowering the shift times for 3-4 and 4-5 but huge changes don't net hard hits on the shifts,, what pressures are you running on the 3-4 4-5 shifts and shift times ,,also I cured the 3-4 shift flares by going into the engine tune and added 1.15 %to the air mass table advised by other forums huge difference there ,, motors pretty much stock (cat back and cold air ) might put the nos on it ,, any input would be great ,, thanks gmonde
