Hi,
I just ordered HP Tuners Pro and and reading up on my options to proceed once its hear. My setup is a gen 3 vortex 5.3 with a 76mm turbo, 80lb injectors, LS1 intake, cam etc...(in a 1972 c10) I got a base map from JSRacing who has the exact same setup for the most part and the tune has all the injector info and is an open loop SD tune. My question is the tune was done in PA which has a significantly lower altitude compared to Utah which is my location, so could i just change the entire primary VE table in by leaning it out in % increments until i got a idling. My logic is higher elevation less air, all the other fine adjustment on the other tables would be close and i could start tuning from there? The truck will start up and idle for a second or two and then idle down and die. If i try to give it throttle it dies immediately. Thanks
