Results 1 to 10 of 10
Thread: Dead pedal when in gear
    Tuner TexasGMC08's Avatar
    Feb 2013
    Fort Worth
    102
    Did a LT swap in a 92. Ever since swap we have a dead pedal only in gear in ramp in WOT. You can pop the throttle in park and it responds. But in gear there is a dead pedal like when you Zero out TM in the 07+ Trucks. Thanks!
    JRXTuning & Performance
    Fort Worth Texas
    [email protected]
    2011 CTSV https://youtu.be/WUuGxYNfJjk
    2008 GMC Sierra 5.7, Nitrous Outlet 200shot, 4.10 gears (Sold)
    2007 GMC Sierra 4.8 4/7 drop, Tune only
    2007 CTS-V BTR STG4,TFS225,MSD Airforce,102NW TB
    Mar 2010
    Texas Hill Country
    3,299
    post tune
    Feb 2013
    Fort Worth
    102
    It's the stock 2014 pcm. No codes.
    If driven calmly the pedal response is good and works flawless. When tires break loose like in a power brake pedal goes dead until you key off for a couple of minutes. Then key on and it's back to normal.
    Fort Worth Texas
    [email protected]
    Mar 2010
    Texas Hill Country
    3,299
    brake torque management needs to be disabled it sounds like....probably a bunch of stuff if it is stock cal.
    Feb 2013
    Fort Worth
    102
    Well pre GM It's a ebcm communication issues. Might need to disable all TC functions or need a DBC TB . Brake TQ in TM is disabled.
    Fort Worth Texas
    [email protected]
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    Are you feeding the ECM a VSS signal? I've seen that cause this issue before.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
    Feb 2013
    Fort Worth
    102
    Yes we are.. We can break torque it and once we do that the pedal goes dead and takes a couple cycles for the pedal to relearn its self.
    Fort Worth Texas
    [email protected]
    Mar 2010
    Texas Hill Country
    3,299
    some kind of limp mode? what have you done with the Diag tables?
    Feb 2013
    Fort Worth
    102
    What ever is not used its Disabled.
    Fort Worth Texas
    [email protected]
    Feb 2013
    Fort Worth
    102
    Update on issue... Had a faulty pedal sensor.. Truck is fine and with a happy customer!
    Fort Worth Texas
    [email protected]
