Hi Guys,
I have a set of Seimens deka 80lb injectors, I have used the Banish Data but im not 100% sure if the min inj PW is correct at 1.1 ?
Has anyone played with / experimented with a smaller min PW ?
Issue im seeing is on decal its going really rich, around .72 lambda
Is this normal ?
Should I keep pulling values from the sub 40kpa on the VE ?
Also wandering what could cause a lean spike when touching the throttle initially ?
Is this maybe transient fueling issues i need to tweak ?
Any help would be great !
Cheers guys
Dan
