Originally Posted by
96gt4.6
This guy is correct.
Ford uses a VID block (HP Tuners does NOT read this) which is short for Vehicle ID block. This 'block' of data contains relative vehicle information such as gear ratio/tire size, ect.
HP will indicate an improper tire size and ratio even when reading a stock tune. They have given us the ability to over ride the VID block with the drop down enabler, at which time you input your new values and tire size if necessary.
This is why your speedo's are accurate, your scanner MPH is accurate, yet the indicated data in the Editor are different.
