STIT =quick changes within a set boundary. LTIT = trims learned from STIT. Did you read the help file?
1961 C-10 5.3 NV3500
2007 NNBS ECSB 4.8
I didn't get to it yet will read it tonight and try it in morning. Ran out of gas in truck wed n haven't messed with it since. I got SD tune loaded n logged a bit but then it went lean and died.
got idle afr dialed in pretty good. truck isnt legal so need to find a way to go do some driving to get more logging info. thanks for the help. idle cells are pretty low compared to other tunes i have seen and compared to. 50-60 kpa VE is at 35. will try n get truck moving around and get more logs. thanks again for the help.
Been driving quite a bit. Noticed truck has no power under wot from stop. Ve is dialed in afr commanded in pe is 12.5 will post log in few
maf tuning.Layout.xml
79 ford 5.3 80e idle drop maf corrections 1.hpt
lunch drive no power wot.hpl
short cruise on lunch break, wot at begining of clip
