Page 83 of 87 FirstFirst ... 3373798081828384858687 LastLast
Results 1,641 to 1,660 of 1732
Thread: VCM Suite 3.0 Is Finally Here!!!
  1. #1641
    Sep 2006
    Syracuse, New York
    299
    Have you tried reading it? That would be a good first step.
    Yeah I read and sent the file in a little over a week ago, ticket #36727. Haven't received any responses to my emails yet other than the initial reponse saying that the file was passed up to an engineer
    Thanks for your quick response
  2. #1642
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,298
    In that case we have no eta.
  3. #1643
    Sep 2006
    Syracuse, New York
    299
    Quote Originally Posted by HackAbuse View Post
    I know there's no ETA on this, but is it at least being worked on? I'm about to lose an important customer over this because we are both completely in the dark.
    I'll let the customer know
  4. #1644
    Oct 2015
    9
    I can no longer see readiness status of smog monitors in scanner. Shows DTCs and says readiness but doesnt show any of them. Talked to my tuner and he said the new 3.0 doesn't have this. I no longer have 2.24 and cant find my CD or a place to download it.
    Have to say I am really surprised they made so many changes in one huge overhaul. No wonder there are so many problems.
  5. #1645
    Sep 2002
    Chicago, IL
    6,397
    They were not removed from the software.
    Please contact support.
    We got this guy Not Sure, ...
  6. #1646
    Feb 2006
    South Carolina
    1,525
    Pretty sure they show up when you select "Read DTC"
  7. #1647
    Oct 2015
    9
    Quote Originally Posted by ElecTech View Post
    I did that but none of the readiness status show up at all.
    If its not removed then where is it ? Have to contact support for what should apparently be an easy answer ?
  8. #1648
    Sep 2002
    Chicago, IL
    6,397
    It's on the Diagnostics and Information control. YOu hit Read DTC's, and it will read the dtc's and readiness states.
    If it's not working, you have to contact support so we can fix it for you.
  9. #1649
    Oct 2015
    9
    Okay I figured it out. You have to click scan. Then click to stop scan. Then click to check for DTCs. Previous version you had to click scan then check for DTC. Not stop scanning.
  10. #1650
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    You can just hit connect to vehicle instead of having to start scanning then stopping.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  11. #1651
    Dec 2008
    on the Dyno
    1,825
    Since this is a continuation of 3.0 I wanted to post up some things that I see that still need fixed/updated. Over the last couple months the software has gotten a lot better mainly in the scanner.
    Here are some things I think that still need addressed and I added in some things I'd like to see changed/added if possible.
    Editor:
    -Table views are not stored when tables are opened or closed. This is frustrating when you constantly open/close a table and have to resize and select side by side for 2d/3d view.
    -Import/Export tables.
    -Add a slider bar on 3D axis so us without a right/left click trackpad mouse can rotate and zoom.
    -Adding ability for variable cam VVE calculation. Currently I can only seem to get zero degree cam angles to calculate.
    Scanner:
    -Ability to highlight a row/column in histograms/graphs by clicking on the axis identifier. Ex. I want to highlight the 95kpa row across all rpm range so clicking 95kpa on the axis will highlight the row rather than having to manually click/drag to highlight data. The Editor already does this for it's tables.
    -More Maths slots.
    -Ability of Maths to use other Maths in parts of equations (like 2.24 allowed).
    -Rename the "Chart vs Time" and "Graphs" back to how they were labeled in older versions. When I think of graphs I think of data lines on a plot not a histogram. Graphs=currently called Chart vs Time and Histograms=currently called Graphs.
    -Allow Maths to be placed on Channel List and the definition of those Maths saved with the Channel List for easier export/sharing with others.
    -Serial WB support for ECM AFM1500.
    -Ability to clear current populated data in histograms/graphs similar to how the older scanner gave that option to clear data out of the histogram and start fresh re-polling while still continuing to scan.
    -Gen3 RTT functions stabilized and functional with the possibility of auto tune VE.
    Located in Central Kentucky
    ShorTuning
  12. #1652
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by LSxpwrdZ View Post
    Editor:
    Scanner:
    -More Maths slots.
    That list pretty much sums up everything I was thinking. Mine seems to have added more math parameter slots somewhere along the way? So not sure if that happens once you use most of them or if mine is just a fluke? I've got 20 now.
    I would also add
    -Add the ability to include math parameters in exports.
    -Fix issue where ctrl+Z in Editor while in differences view doesn't work correctly
    -Fix issue where when changing multiple selected values, if the first one is the same as the value typed in, no values are changed. i.e. if I select say 10 cells. The first one I click on is say 10, the rest are 12. I want to change them all to 10. Type in 10, hit enter, nothing happens. If I select a 12 first, select the same exact cells, type 10, hit enter, and everything is changed to 10. Seems like it's only checking the first cell to see if it already matches the new value. if so, it doesn't change anything (even if every other selected cell is different)
    -Add back smoothing, etc while in differences view (I know this is unlikely, but I'll ask anyways)
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  13. #1653
    Nov 2005
    Houston, TX
    3,968
    Editor:
    Scanner:
    -More Maths slots.
    Some good stuff here.
    Bill Winters
    Out of the LSx tuning game
  14. #1654
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    Especially this... drives me nuts not being able to highlight entire row/column: "Scanner: -Ability to highlight a row/column in histograms/graphs by clicking on the axis identifier. Ex. I want to highlight the 95kpa row across all rpm range so clicking 95kpa on the axis will highlight the row rather than having to manually click/drag to highlight data. The Editor already does this for it's tables."
    2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
    Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
    LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
    ZL1 Wheels/Tires
  15. #1655
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    I thought I was the only one that was driven crazy by that, lol
  16. #1656
    Nov 2005
    Houston, TX
    3,968
    The draw max on the speedometer in the gauge stops at ~36 MPH pretty much every time I scan.
    Bill Winters
  17. #1657
    Sep 2002
    Chicago, IL
    6,397
    Editor:
    That, along with the compare undo issue are fixed in tomorrows beta.
    Please request access and test.
  18. #1658
    Sep 2006
    Syracuse, New York
    299
    It appears support for the TC-1791 in the 2016 Mustang 3.7L has been released - I'm now able to read tunes with today's release. Customer will be by tonight so we can have a crack at it
  19. #1659
    Does disabling the vats patches in 3.0 work for the 2008 silverado?
  20. #1660
    Sep 2006
    Syracuse, New York
    299
    Quote Originally Posted by sunny View Post
    Speaking of VATS, what happened to relink VATS and Write Entire functions? I have my personal vehicle here and the VATS system activated sometime within the last year and now I can't get it to crank...
