Page 5 of 87 FirstFirst 1234567891555 ... LastLast
Results 81 to 100 of 1732
Thread: VCM Suite 3.0 Is Finally Here!!!
  1. #81
    Tuner in Training Jim Ferraro's Avatar
    Jan 2016
    Orlando, FL
    29
    Awesome!
    I wonder if this new licensing feature also makes Roush files able to be licensed.
    Jim Ferraro
    Ferraro Speed Parts Inc
    (Distributor of the HP Tuners nGauge)
    407-588-7546
    [email protected]
  2. #82
    Jun 2011
    Montreal, Canada
    758
    If I download 3.0 onto my laptop...and keep 2.24.... will there be any issue using the editor and scanner of 2.24 until I used to 3.0 and get it all set up?
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
  3. #83
    Dec 2008
    on the Dyno
    1,825
    Where are the "database" files that the new version uses? In the older version I would copy these files between my tuning computers so that window sizes, locations, favorites, units selection etc could be kept without having to setup every vcm suite on each computer.
    Located in Central Kentucky
    ShorTuning
  4. #84
    I am just glad the VVE wizard is there, manipulating the tables and graphs in the Bluecat tool was a pain. But now I have to setup new configs from scratch, that is not going to be fun.
    2012 Camaro SS/RS M6. TVS2300 w/rear OD cog drive and ported lower manifold, On top of a forged 416.
    1999 GMC Sierra 2500. Stock 6.0L, LT headers, cat delete, and Airaid intake.
    1965 Oldmobile Cutlass. 5.7L LS1/4L60E transplant in progress from 98 TransAm donor car.
  5. #85
    HP Tuners Developer Saif@HPTuners's Avatar
    Jun 2010
    Buffalo Grove
    6
    Quote Originally Posted by CornDog View Post
    Is there a help file, I looked for a minute but didn't see anything
    You can click Help on the menu or you can also go to http://www.hptuners.com/help/VCM-Scanner/ for VCM Scanner and http://www.hptuners.com/help/VCM-Editor/ for VCM Editor
  6. #86
    Sep 2002
    Chicago, IL
    6,395
    Quote Originally Posted by LSxpwrdZ View Post
    Same VCM Suite.cfg, VCM Editor.cfg and VCM Scanner.cfg files as 2.24, located in My Documents\HP Tuners\Settings
    This is also documented here: http://www.hptuners.com/help/vcm-sca...hitecture.html
    We got this guy Not Sure, ...
  7. #87
    Jul 2005
    37
    Quote Originally Posted by MattH@HPTuners View Post
    What is your OSID?
    Don't know exactly where to find this. I'm HPT dumb. Not my forte but I'm trying.
    Also, I noticed that when you fully close out and reopen, it opens the last file you were in as well as any table that was open when you close out.
    I also noticed that when you try to make a change to an existing licensed file, it will ask you to license. But just click yes and it flips through and automatically loads it from the cable.
  8. #88
    Dec 2008
    on the Dyno
    1,825
    Okay the table options aren't sticking... Meaning if I open up "Main VE" and I resize the window and switch it to side by side with 3d graph and then close it out and re-open the "Main VE" it doesn't pull the window back up in the last location. This is a bit of extra steps everytime you need to get into a parameter to edit it you have to resize the window and reset the size and placement of the 3d graph display and orientation.
    ShorTuning
  9. #89
    Dec 2013
    15
    Hey, so... This is fantastic and all, but now do I need to rebuild all of my 10+ scan configs I built over the years in the new scanner? This is going to be a major pissoff guys..
  10. #90
    Sep 2002
    Chicago, IL
    6,395
    Ahh yea that was reported. We should have that in 3.0 later this week.
  11. #91
    Sep 2002
    Chicago, IL
    6,395
    Quote Originally Posted by DeeJayZee View Post
    Build one config in 3.0 and you'll see how much less time it takes than 2.24. There is filtering and searching to make the whole process MUCH MUCH quicker. It's no where near as difficult and time consuming as it was in 2.24
  12. #92
    Dec 2013
    15
    Much easier to build custom PIDs like map - baro for boost etc? I feel as though I have another years worth of work ahead of me just ironing out the new setup lol
  13. #93
    Sep 2002
    Chicago, IL
    6,395
    Much easier! And boost is already built in!
  14. #94
    Dec 2013
    15
    Awesome, your statements seem optimistic, thank you for that! haha
  15. #95
    Mar 2008
    Paris, France
    435
    Damn ... installing the 3.0 delete the previous 2.24 version.
    Do you have a download link to the last 2.24 version (to install it on another computer).
    I have a lot a work and config on 2.24 scanner. +Virtual VE tool I've customized for 2.24 editor.
    Is Virtual VE fonction effective in 3.0 ?
    http://www.lsxcalibration.com - Lsx Tuning France - Spécialisé Reprogrammation moteur Corvette Camaro Hummer, Ford Mustang et autres véhicules US
    Check our Facebook page http://www.facebook.com/lsxcalibration.com
  16. #96
    GM VIRTUAL VE
  17. #97
    Sep 2006
    Arizona
    600
    Okay, so I am able to build up a new scanner layout pretty quickly. Without having a car here to test on, I was able to build one using previously captures logs.
    I had to scrape myself off the ceiling and go take some advil and drink water. This trainwreck isn't so bad afterall, but just a massive pain in the butt.
    Having trouble getting fuel rail pressure for the LNF to show in the Histogram area, but can see it in the left hand display.
  18. #98
    Sep 2002
    Chicago, IL
    6,395
    Quote Originally Posted by PSYKOSTEVO View Post
    I had to scrape myself off the ceiling and go take some advil and drink water. This trainwreck isn't so bad afterall, but just a massive pain in the butt..
    We understand COMPLETELY!!! We will do our best to make this as easy as possible for everyone.
    We're confident in the new scanner interface. The feedback has been overwhelmingly positive. Sure, it is different, but, it's better!
  19. #99
    Sep 2006
    Arizona
    600
    Quote Originally Posted by steelmesh View Post
    GM VIRTUAL VE
    Is it just me, or has anyone else been using this for a while? Seems like it has been in the Beta for a long time.
  20. #100
    Dec 2013
    15
    Already found a hiccup, new scanner wont read load % properly.. :/ *sigh*
