Page 61 of 87 FirstFirst ... 115157585960616263646571 ... LastLast
Results 1,201 to 1,220 of 1732
Thread: VCM Suite 3.0 Is Finally Here!!!
  1. #1201
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Yeah, comments/marking hasn't been added to V3 yet. I'm looking forward to at least some sort of marking being added.
  2. #1202
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    2. Open a file, make a change. Hit on the X in the top right to close the program. When it asks yes/no/cancel regarding saving, hit cancel. Program closes without saving. Cancel should cancel the exit and take you back to the program.. not exit it
    does the same for me, it closes the program, not cancel the close.
    Is frustrating when I make a bunch of changes, and accidently hit the x, and I click cancel fulling expecting it to cancel the exit, not the save, like every other program on earth, then poooooooof all is lost.
    I will now click save, but still, was something unexpected
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
  3. #1203
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    That's exactly what happened to me twice yesterday... I'm not sure why I can't duplicate it now but I swear it's done that on me for a while. I finally got in the habit of hitting ctrl+s often to save changes
  4. #1204
    Sep 2007
    393
    I tried opening my tune with both version 3.0.21 and 3.0.38 but couldn't reproduce the error you're seeing (realcanuck in post 1181). I did however notice something even more interesting.
    Take a look at the screenshot and see if you can spot the three things wrong with it. The answers are shown below it.
    Problem #1: Even though I have the units set to Imperial, the values that appear in the 4-5 window are clearly Metric.
    Problem #2: On that same window, the label shows lb-ft even though the values in the table are Metric.
    Problem #3: Although you can't see the cursor in the screenshot, I'm hovering over one of the 4-5 upshift tables but it's showing kPa in the microhelp on the bottom right of the window.
    I also noticed that even with the units set to Imperial only the 1-2, 2-3 and 3-4 tables for Upshift - X are actually Imperial as the rest open up in Metric.
  5. #1205
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    If you change the units to metric then back to imperial does it update these or stay the same?
  6. #1206
    Sep 2002
    Chicago, IL
    6,397
    Some default units are metric, even if you select imperial.
    For example, MAP axis will be kPa because that is what is most used, even in imperial locales.
    We got this guy Not Sure, ...
  7. #1207
    Jun 2011
    Montreal, Canada
    758
    Quote Originally Posted by thesubfloor View Post
    Seems the universal setting doesn't change these... I have to go change the units table by table.
    Hey Chris... you don't get those ??? in yours ?
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
  8. #1208
    Jun 2011
    Montreal, Canada
    758
    No change. .tried that already.
    Alky Control Meth,
    ARH 1 7/8 headers,
  9. #1209
    Sep 2007
    393
    Dup post.
  10. #1210
    Sep 2007
    393
    Quote Originally Posted by Keith@HPTuners View Post
    While that may be true for some parts of the program, it isn't the case here as all of those tables should switch back and forth based on the selected units. It works properly in 2.24.
  11. #1211
    Sep 2007
    393
    Quote Originally Posted by realcanuk View Post
    No, I didn't see any ??? when I tried opening it.
    If you still have my email address send me the file and I'll try opening it. Should be interesting if you see them but I don't.
  12. #1212
    28,285
    when you make a units change to an individual table the software recognizes this and stores the settings as individual so even when you change the "group" settings it won't modify the settings you made to that single table.
    I believe you can get rid of this by deleting the VCM editor.cfg file, its either that or the suite.cfg file, been a while since I had to mess with that stuff.
  13. #1213
    Jun 2011
    Montreal, Canada
    758
    Sent.....
    Alky Control Meth,
    ARH 1 7/8 headers,
  14. #1214
    Sep 2007
    393
    Nope, that didn't work.
  15. #1215
    Feb 2014
    17
    Gauge / chart display issues
    The gauge and chart show strange values and oscillations on some channels. Seems to be when using multiple channels that have similar units. I understand that it might be good to interpolate between values of a given channel when there are data "gaps" in time, but I don't think it should be doing what it is doing. It appears to be averaging between 3 similar channels when only one is selected to chart. No idea where the bouncing is coming from but it is really strange as the chart data doesn't do anything like that.
    Screenshot of a G8 doing it with vehicle speed and an Impala doing it with O2S. Using 3.0.36 and 3.0.37:
    I was hoping to use the broadcast speed channels on the G8, but they don't seem to work (always show less than 2mph). Another one for the list...
  16. #1216
    Sep 2002
    Chicago, IL
    6,397
    Looks correct. You're plotting against a Sensor, most likely,so it will take into account all Channels that represent that Sensor.
  17. #1217
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Interesting
  18. #1218
    Dec 2014
    592
    But aren't two of those channels absolutely wrong (1mph in the pic, always less than 2mph) where the other is 59mph)? If they were closer, it might not be such a big issue (if I'm understanding the issue properly).
  19. #1219
    When i try to export a table I get a popup that says not implemented. I have been upgrading every day hoping this gets fixed but i just got the newest version and it is still doing it.
  20. #1220
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    That is a feature I'd like to see working as well (also, the import feature..)
    I can always copy/paste to Excel
