Help Getting MAF lo and hi AFR error Histo synced to Wideband for data logging
Cant figure out how to sync my wideband to the MAf lo and hi afr error histograms. I downloaded the files from the HP tuners tips sticky but I just cant get them to work on the scanner. attached is my scanner config.
kenny gixxer.cfg
It's pretty simple. Using the built in "AFR error" PID has literally never worked for me, so I would make your own instead. It can be done several ways
Is your WB in lambda or AFR?
What vehicle/ECM is this on?
What is happening when you try to record while using these histograms? Blank, bad data, what?
