Results 1 to 12 of 12
Thread: Siemen deka 60lb injector issues need help
    Mar 2015
    9
    Hey Guys,
    First time doing an injector change tune, have tried getting my tune up spot on but car keeps flooding itself at idle and wot, have only modified ifr table and just multiplied my old table by 2.31 as my standard injectors are 26lb have a v2 vortech charger, does anyone have a tune with the injectors specs or any help would be grouse, thanks
    Feb 2008
    Scott, LA
    12
    Just changing the IFR table by some "calculated number" will not work. You need the correct injector data. The IFR tables, Injector offset, SPA and Min PW tables need to be correct.
    2004 GMC Sierra 2500HD 6.0/4l80E
    Advanced Tuner Auto-Hentzschel's Avatar
    Sep 2015
    Schleid, Germany
    341
    Here are Ford data. You can covert it from there. but Ford use 40PSI Fuel pressure...
    https://fordperformanceracingparts.c...-9593-lu60.pdf
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    You will need to convert the Ford data to GM and your 58 psi fuel pressure or get Greg Banishes first DVD which has a injector data cd and the Siemens 60 is included.
    Ford to GM Injector Data Conversion R3.xlsx
    Ed M
    [email protected]
    Aug 2012
    SV, AZ
    447
    Hey geniuses, let's check part number first lol. There are a few different "60lb" Siemens injectors out there. The ones ones the Banish DVD are actually ~63lb at 3 bar.
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by Eaglegoat View Post
    He asked a question, he got an answer based on his detail.....and not to split hairs but the injectors in Banishes CD are :generically" known as Siemen Deka 60's....not Siemen Deka 63"s! And lastly regardless if he cant find GM data then he his going to have to convert using the converter above as well.
    And thanks for the nice opening LOL
    Ed M
    [email protected]
    Aug 2012
    SV, AZ
    447
    There's seriously smart guys on this board.
    One of my biggest pet peeves are things like the 63lb injectors being called SD60s. There's several injectors from SD/Continental that flow ~60lb.
    So OP what's the part number? That will let us help you get on the right track.
    Mar 2015
    9
    thanks for the help boys!!
    Mar 2015
    9
    the part number for the injectors are VDO SIEMENS Part#: FI114961
    Mar 2015
    9
    i got the car to run, it runs great, wot afr on the dyno is 11.8:1 just is rich at idle doing around 12.8 at idle, at cruise its 14.7:1
    Mar 2010
    227
    did you get the correct injector data for the siemens 60s?
    1993 reef blue Mustang coupe
    Ls1 conversion
    1 7/8 cooks headers
    AFR 205 heads
    Fast 92/92 intake
    PAT G./ EPS Custom cam 230/234 .600”/.602” 112LSA +2 advance
    century Built 4l60e with Circle D 3500 converter
    4.11 gears
    Feb 2012
    TEXAS
    635
    hope this helps
