Originally Posted by
Higgs Boson
I definitely wasn't thinking of them as vacuum however, every Baro reference I have seen has been as a baseline to map. In other words, Baro is outside the engine and Map is inside (the intake manifold).
With that said, the Y values make no sense because when will you see 18 in/hg outside the car? You would have to be on Mars or something.
So I am glad you pointed out that it must be cylinder or manifold pressure, which could be calculated I guess since the Mustang does measure Vacuum.....or it could all be calculated, like MAP.....
Why they wouldn't just use Calculated MAP for the Y axis is beyond me....They use Desired Air Load (rather than actual) so I don't really get using Baro in place of MAP. I really wish this car had a MAP sensor!
I'm not sure if this changes my values in the tables or not, I will reevaluate them.
