How can I shut off the traction control on this 2010 F150.
Thank You
Thank You
On my 2011, the only way to completely remove the nannies is to pull the relays/fuses. ABS wont work either.
With Diablosport and the Mustangs if you put engine displacement to 0 it disables the traction control. Just curious if there was a way with HP.
There should be a setting like that under torque management in the engine tab. If the truck is a 5.4, the box might have 54 in it the stock tune, set it to 0 to disable the traction control. I forget what it's called , but the description specifically says, "set to 0 to disable traction control". Using this method gives you all sorts of idiots lights and disables abs, so it's not a great solution really. There's possibly a way to disable traction control from pulling spark under the torque management tab but I never got a solid answer on it.
