I've corrected a few things in our scanner so that a lot of the missing parameters for the newer PCMs (Copperhead and newer) should show up.
Some of the items that now work:
Idle Desired RPM
Fuel Pump Commanded DC
LTIT (
Commanded Gear
Desired Gear
TCC Slip
TCC PWM Duty Cycle
PCS A Desired Current
Trans Input Shaft RPM
Trans Calculated Gear Ratio
Trans Output Shaft RPM
Trans Fluid Temp
Trans Fluid Temp Sensor
TCC BiDir State
TCC Desired Slip
and more...
LTFT should report properly across the board now as well.
