Im stumped. I've been searching for hours, and i've made about 15 different changes with my tune and nothing makes a bit of difference. I put an LS2 out of a 2006 GTO into a 1979 camaro. The ecm is an E40. 24x reluctor. the factory dash tach is for a V8. I had no tach movement when run off the tach output wire at the beginning so we had to use a pull up resistor ( i've tried, 300, 600, 4700, 10,000 ohm) and its the same no matter what. My RPM's are reading exactally half of what my VCM scanner is showing. I have tried changing the Hi/LO res from 2 all the way to 15, and its the same every time. I've done this several times with LS1 swaps and it works like a charm, this time it acts like my changes don't have any effect.
All the search info i could find was on the E38 ecm, not the E40. can anyone please help??
