Results 1 to 10 of 10
Thread: Formula for AEM 30-4110 Custom UDEIO
    Mar 2015
    233
    I have the documentation for my wideband which includes the voltage to afr/lambda chart. However, I dont know the formula to create the settings needed in the Cutom UDE i/o. I've tried playing with the input linear chart, from 5v/10 and it gets closer when I use .422v/7.312, but its still just a guess.
    What is the formula we are supposed to use?
    I'd like to stick with AFR instead of lambda for the time being.
    Thanks,
    2011 Camaro SS
    Thompson Motorsports Dart 427
    ESS Tuning G4 Supercharger 1158whp/1017wtq
    DSX Tuning stuff
    Mar 2015
    233
    just found the wideband voltage offset spreadsheet. report back soon
    2011 Camaro SS
    DSX Tuning stuff
    Mar 2015
    233
    This spreadsheet if for minor changes. My wideband is reading 14.4 at idle, and my HPT is reading 10.4. Something is way off... I made sure to run a ground wire from pin 5 from the MPVI to the same chassis ground that I used for the gauge itself, so it shouldnt be a grounding issue. I'm stumped.
    2011 Camaro SS
    DSX Tuning stuff
    Mar 2015
    233
    DUH! I didn't see the . Supposed to use .5 and 10 in the scale. I used 5 and 10. Got it tweaked out perfect now. Had to use the voltage offset calculator to adjust for a voltage difference of .25 However the instructions that came with the calculator tell you to adjust in the wrong direction. Had to do the opposite to get it right.
    2011 Camaro SS
    DSX Tuning stuff
    Mar 2014
    11
    I think the AEM is already listed in the Wideband O2 sensor drop down. I just installed mine last night and it seems pretty accurate, but it doesn't have any adjustments that I know of.
    Oct 2016
    37
    need to know how to make it show afr
    Quote Originally Posted by justhereforinfo View Post
    Thanks,
    even how this forum is set up, ugh. not sure if I'm typing n the right spot. anyhow, I have the aem 30-4110 how do I get it to read afr. it has 2 wires a white and a blue. I have the white hooked to term 1 and nothing to the blue. is this why its not reading as AFR? where does the blue wire go they keep sending me the pin out for the tuner and that doesn't tell me shit about where THIS wideband should be hooked up. if you can give any input most ppls answers are so vague. thanks
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    White goes to input 1 (pin 1) on HPTuners interface
    Pin 5 or 6 need to be connected to same ground as gauge is connected to
    Step by step setup:
    http://www.hptuners.com/forum/showth...PRO-Interface)
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Nov 2008
    Tampico Bay, Mexico
    220
    mine worked great until the las update of the HP tuners software now im off by 2 Afr points I try move the offset and all of that with no succes ...any idea the wideband its working right I just use it to tune a friends f150 with a microsquirt and it reads and logs right on the spot I dont know what coul be happening
    all the way from Tampico bay Mexico
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Post log, channel config, SOMETHING for us to go on
    What version were you on and what version did you update to?
    Best bet is to just delete the wideband channel and set it back up from scratch. It shouldn't take more than a minute or two at most.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Nov 2008
    Tampico Bay, Mexico
    220
    sorry on the logs i have the scanner dont poll the wideband on the chanel list and the car is without tranny right now i upload logs and screenshots as sonn as i can connect to the car.. by the way is a 85 camaro swap 5.3 and maggy SC ,I make some logs with the wideband almost a week ago but i deleted them now that I was going to make road test and WOT pulls the trouble with the WB begins
