From what I've read is it just as simple as turning on the flex fuel option on and to sensor nor virtual, and driving off? Or are there some tables gm left untouched to properly ethanol. Also on the flex fuel spark modifier table, is there room for more timing isn't the cylinder air mass range of .54 to .75 for 4200 rpm on up to redline? Those areas of the table are taking away timing instead of adding
