Hi Everyone,
I have this nagging dip in power with my TT corvette. The car makes great power, runs great (minus feeling the dip at WOT) I've tried a million different things to fix the problem but I simply can't find where the problem lives.
First I'll explain what I've tried:
timing adjustment (higher and lower) in this spot. No change
fuel adjustments (leaner and richer) current AFR 11.65. No change
I tune the car myself but I've had 3 other tuners look at the logs and current tune and we can't find an error.
Different intakes. No change
Different exhaust manifolds. No change
Measured back pressure (pre and post turbos) all within reason.
Information:
It looses 100whp and 130ft lbs of tq
It is always at the same RPM.
It did it with my old 408 and different cam/heads
Currently still does it with my 426lsx
Boost is solid (no dips or spikes)
Zero spark knock
AFR is solid
The dip only noticeable above 1000hp.
I'm running the stock E40 ECU. I think I'm one of the few and maybe the highest with this 1 off GM computer. Maybe it's a problem but we can't find it?
Any thoughts?
