I have been logging this and they do not match. Should they? If they don't, does that me the VE table is wrong?
www.outlawpontiacdragseries.com
Come race with us in MA, PA, and VA!
2005 GTO A4 - Spintech X-pipe with Powerstick mufflers, IAT relocate, Volant, !scoops, !cowlgasket, !skid plate, LM-1, HPT2.0/MPVI Pro USB, 275x40x17 Nitto DR, rolled fenders, Pedders 2985 springs, Britax baby seat with 5 point harness.
Stock:13.36@104
Mods in sig:[email protected]
dynamic is calculated by the computer based on the VE, IIRC. The MAF is calculated by the MAF, they should match. This means your VE and/or MAF is not done correctly
Sulski Performance Tuning
My MAF might be boogered and that's why stock VE and Tim's VE haven't made it run any better. I either need to tune this specific maf or there's something wrong with it and it can't be calibrated. I assume that it is possible for a maf to not be able to be calibrated?
I have a ported 98 LS1 MAF, can I plug that in on my 05 GTO LS2 and try it if I have relocated the IAT out of the LS2 MAF?
Stock:13.36@104
tuning MAF is nothing else but matching it to VE. of course, there's no point of doing so unless VE is done right, because then you're gonna end up with both of them giving you wrong info. when they differ too much tho, it's a good sign that you oughtta retune. they are usually a bit different, as one is a calculation from many components, and the other is just a simple table lookup. dynair usually looks way more choppy.
Don't forget Chris' sponge analogy.
Dynamic airflow should be the same as MAF in steady state. If not, retuning is necessary. During transients the Dynamic airflow moves more in short duration to compensate.
I created a PID to calculate MAF Error% vs dynamic airflow.
EC
Always Support Our Troops!
So I need to be at steady cruise to really tell if they are close? Is WOT a transient situation? Its purely VE at that point and not looking at the maf correct?
Stock:13.36@104
Above 4000 RPM it's all MAF, below 4000, it's a mix of VE & MAF.
do u have a formula you can post?Originally Posted by EC_Tune
I need to dig it off my laptop @ work. But yes I will post it.
basically its:
100*(Dynamic Airflow-MAF Airflow)/MAF Airflow.
SWEET info.... and good recommendation for Dynamic Air vs. MAF error %
2007 CTS-V LS2
100*([pid.2320]-[sens.40])/[sens.40]
thanks!
EC, what do you do with this formula?
Stock:13.36@104
I was playing around with it just to see what happens during transitions. The dynamic airflow definitely moves faster than MAF.
