Goin from 2006 crewcab to 2001 single cab engine swap
I have a 2006 5.3l in a 2001 single cab, the 06 was elec throttle body and the 2001 is cable by wire, i have the 2 tune files for both trucks. The 06 was turbo and every thing got transfer over except the harness, so i wanna use the cable throttle on the 2001 for the swap. The trks start and runs, but aftr you hit the throttle if shuts off. I manually transfer the tune from the 06 to the 01 competer except the throttle part im stuck there. Blue silverado is the 06 file and sinlecale is the 01 file
