Pre.
Pre.
Random84, schpenxel - here is the tune I am working on now. I am sure it will be a mess, but idle is 750rpm, and I have a 175* thermostat.
On fueling your short pulse limit should be 3 and your Makeup Pulse Min should be .125 across the table. Other than that you have the basics for injectors down for ID850s as far as I can see comparing to my ZL1 tune when I was running them. The rest you have some work as everyone has said. If you ever get this to Montana I could help and I have a DynoJet Dyno to finish the tune on.
I am going to put in a shameless plug in for Dr. Mike's work here. I owned to different widebands before buying two (one for each bank) AEM 30-0333 OBD2 type devices. Would never go back. Today I just converted a friend (4 year tuner) over to these. Jumped in a car plugged it in and boom. Perfectly synced lambda data in HP Tuners. No ground offset issues on serial cables and they are FAST. FYI I learned that I have 1 bank running 2% leaner than the other and with the E67 you and I both have I was able to adjust that to make the banks match.
Here is another piece of advice. My car which had a build similar but with a TVS2300 Heartbeat is sitting in the garage right now waiting to be tore down because I bet it all on a cheap part that failed. Seems GM knows that the oil pumps (even in the ZL1 which is supposed to be 33% better) have issues. So while sitting at an idle the pump lost pressure causing the steel gears of the pump to cut into the aluminum housing and send fragments all through the block. Ran for less than 10 seconds that way but 9.9999 seconds too long. REPLACE the oil pump and be careful to do it right.
So what issues are you having and do you have a log?
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
I have the old instructions for adding the wide band AFR reading, trying to find the new instructions. Good to see you are still here!
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Here are my first scan logs, before any changes with wongs tune, then with updated ID850 info.
Tune?
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
hope to start tuning tomorrow, you have any more of those great step by step posts that you wrote?
DID SOME MORE TWEAKS, IDLE IS ALLOT SMOTHER AND AFR DOES NOT BOUNCE AROUND SO MUCH. HOPE IT KEEPS GETTING BETTER WILL CHECK FOR THE ENGINE DIEING WHEN THE CLUTCH IS PUSHED IN TOMORROW. Sorry caps lock, also got the car to run at a stable 187*. I wish I would have done this from the beginning!!!
Was it Wong's that tuned it initially?
10' CTS-V A6. 2.4 upper, ID850, Airraid, Headers, Catless X.
Fuel trims are still at like -26% throughout the entire log and the WB is still reading rich, so something still isn't right.
Post the tune you were using for that last log
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
your idling pretty rich 12.xx and your timing looks to be jumping all over the place...between 8 and 20 advance. that's a lot of drift. think you have some work ahead of you from just looking at that one log. if im not mistaken you seem hesitant to post up your tune, im sure you would get some valuable feedback if you did.
2010 CTS-V A6, Airaid CAI, 2.4 pulley, ported ls7 throttle body, ID850s, ARH 1-7/8" headers and X pipe, TR7IX plugs, MSD wires, Elite catch can, ZL1 lid and Track Attack HX
Sorry go to bed early, so here is the tune and last log, this morning it all changed.... Do not know why, yes something is still messed up. Yes, Wong in Vancouver Wa. did the tune on my car. I asked him to use the ID850 data he said it was not necessary....
All I have done to the tune so far is add the ID850 data, clean up the idle speed screens so they match and cooling fans for lower temp thermostat.
