Hey all, this is the first time I'm posting on the forum but I've been playing around with HP Tuners for a while. I've searched up on this topic a good amount and I've found some tips that have helped... but I'm far from figuring this out.
I've been battling this terrible idle surge on my cammed '04 LS1 GTO. Cam is a 227/235 SNS Stage 2 with stock 241s, stock ls6 intake, and longtubes. I've been using the enhanced 1 bar Speed Density OS and I've gotten it to the point that the car drives great with great throttle response, good fuel economy, fair A/F ratios throughout the rev range (although still running very rich at WOT, low 11s on the wideband while I've been aiming for 12.8), but it idles like complete crap. It used to be so bad that it would jump by 800 rpm and continue surging until it couldn't catch itself anymore and stalls out. I've gotten it to stop stalling out by almost getting rid of my Overspeed spark correction. At this point, I'm lost as to what to try from here. I've tried increasing and decreasing my base idle airflow with no real progress. Could it be too much timing in my base spark table? I haven't had the chance to try it with lower values.
And even though its not the primary concern right now.. why can't I get my WOT A/F to lean out? I feel like my PE EQ ratio is already set way lean and didn't want to continue bringing it down.
I've attached a copy of my tune file if anyone wants to take a look.
Thanks, still in the process of learning all this stuff.
Conrad GTO Tune file 15 SPEED DENSITY.hpt
