Does anyone has the data (coyote) ?
http://www.lsxcalibration.com - Lsx Tuning France - Spécialisé Reprogrammation moteur Corvette Camaro Hummer, Ford Mustang et autres véhicules US
Check our Facebook page http://www.facebook.com/lsxcalibration.com
Roush tune in repository will work.
2007 Mustang GT
305ci big bore (5.0L Cammer block)
Ported heads
Lunati cams and springs
Usual compliment of bolt-ons
that will not work on the coyote due to in being 39psi and the coyote motors work on 4 bar system now
Remote Tuning [email protected]
Just use the rough tune in the repository. It had my trims within 2% first try
What do you guys tweak to get the fuel trims back to normal after you change injectors to avoid "baking" error into the MAF Curve? I have always wondered how you adjust injector data, seems like it's pretty technical, but then again I don't have a good understanding of the functions of the different injector parameters.
Every thing I have read and been told by instructors, is to use good data for injectors. Leave the tweaking to the 'tooners'.
as said above, you use known good data. there is no good way for the common tuner to properly flow and characterize injectors. you either use stock injectors from a bigger application and steal the injector data from the ford stock tune or use an injector company that gives excellent data for their aftermarket injectors, the only one I know of is Injector Dynamics.
OK, that's what I was thinking. Seemed nearly impossible to tweak injector data and I guess that's because it is.
Brining this back!! Anyone have this data, I don’t do Ford tuning but attempting to help a close friend dial in his setup and before we start I told him we need proper data
Email Tunes, [email protected]
15 C7 A8 H/C 2.3 Blower/PI
14 Gen 5 Viper
Ford data will work fine and roush data will work fine as well - roush just took a different route and modified fuel pressure tables.
v-performance.pl/
facebook.com/veee.performance/
https://www.instagram.com/v.performance.pl/
Remote tuning:
[email protected]
+48 697276579
14 Gen 5 Viper
There are modifiers to offset, slopes, and breakpoint based on pressure. The FRPP sheets were built around 39.15psi (with matching pressure comps) and the Roush was built around 55psi (with matching pressure comps). Both work out to almost exactly the same values.
My new fuel injector test bench runs them at 4bar (58psi) and includes output data with pressure comps built around that, which ends up being almost exactly the same as the two above, but extends to 125psi to work with newer 2019+ cars too.
