First of all I can say I've searched and came up empty handed, I've done the TPS reset procedure like 10 times as well. With that said, I'm working on a 01 truck that has been swapped from a 5.3 to a 6.0, has an Edlebrock 90mm cable operated TB, GMPP Hot cam (part#12480033), and has the 25326903 (VIN Z) flex fuel injectors. Just got my hands on the truck last night & was gonna try to get the TPS voltage & IAC steps in line so I could start on the RAF but I've hit a brick wall with this constant 2% TPS with no throttle. Anyone ever have an issue like this? 6.0 SWAP 1.hpt
