Results 1 to 5 of 5
Thread: Need some help
    Feb 2011
    38
    Need some help
    I am helping a buddy with a LS swap in a RX-7. The swapped motor is a 5.3 from an 01 Tahoe with a car intake. The motor runs really bad with MAF connected, and the fuel trims are going up to 50. The o2 sensors are staying low. If we disconnect the MAF, the car runs pretty good, the fuel trims are within 10 and the o2 sensors seem to be working normally.
    Any ideas? I'm pretty new to tuning and such. Thanks
    13,565
    You must tune the motor for the change in intake manifold. The MAF and VE tables are now going to be way off because the truck intake design is different from the car intake.
    Feb 2011
    38
    Thanks. Can I just copy the tables from somewhere, or does it need to be dyno tuned?
    13,565
    You can do everything with real world driving, no dyno needed.
    And no you can't copy and paste from anywhere, they never made a 5.3 with a LS1 style intake.
    You'll want to invest in a wideband if you don't have one and look up how to VE and MAF tune the car and go from there.
    Feb 2011
    38
    I see, thanks
