Results 1 to 12 of 12
Thread: Can't change tire size anymore?
    Tuner in Training BluBeaSSt's Avatar
    Dec 2011
    48
    I know I've been able to change the tire size on this truck before, but now whenever I go into the "Speedo" tab I get an "error" in the current tire size.
    It's a manual 2500 truck so it won't affect how it shifts but I do want to fix the speedo.
    I'm going from a 33X12.5X17 back to the stock 245/75/16 (30.5)
    2002 Camaro SS
    2013 Jeep JK 2 Door
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Ok, I fixed the error for you. Note that trucks with the 245/75/16 tires, use 29.79 for the tire dia. This is to allow for the reduced loaded tire radius.
    Dec 2011
    48
    Thank you sir, but why does the tire section say error? Anyone know of a fix for that?
    2002 Camaro SS
    2013 Jeep JK 2 Door
    Dec 2011
    48
    Quote Originally Posted by Russ K View Post
    Also that didn't change it, it made it about 70mph fast LOL
    2002 Camaro SS
    2013 Jeep JK 2 Door
    Dec 2005
    Regina, Sask.
    4,214
    Post your stock tune.
    Russ Kemp
    Dec 2011
    48
    Here's my stock tune, I can't load it for some reason anymore. I emailed support about it but no word yet.
    2002 Camaro SS
    2013 Jeep JK 2 Door
    Dec 2005
    Regina, Sask.
    4,214
    I can't open your stock tune with either 2.24 or 2.25, has a validation error. But looks like your trans uses a 40 tooth reluctor wheel, not a 17 tooth. So this should work now. Had to change the VSS pulses per mile and the Trans Revs/mile. And the Tire Size error will remain.
    Russ Kemp
    Dec 2011
    48
    Russ Kemp
    That worked, thanks a ton. If you don't mind me asking. How did you change that in case I run into this again?
    2002 Camaro SS
    2013 Jeep JK 2 Door
    Dec 2005
    Regina, Sask.
    4,214
    Quote Originally Posted by BluBeaSSt View Post
    Russ Kemp
    Mar 2007
    Tucson, Az.
    165
    Russ,
    Had great Canadian friend from Regina with me in the Marine Corps in the late 60's named Merv Kennedy. When he returned there, he became a home builder. Now may have moved to South America. Know him? Had a Corvette back then.
    SOLD - 2005 C6 6.0 LS2,TF 235 heads, 245/255 .630 113 LSA cam, LS7 lifters, YT 1.7 RR, FAST 102 LSXR, VMax 90-102mm, VMax CNC ported TB, LS7 injectors, Dewitts radiator, Manley 7.550 pushrods, LS7 fuel pump, PowerBond 25% UD pulley, RPM stage 2 '06+ 4:10 rear end, Callaway CAI, 160* thermostat, HP Pro custom tune, LG Pro headers
    Now - 2016 C7 ZO6 A8
    Dec 2005
    Regina, Sask.
    4,214
    Quote Originally Posted by jim2092 View Post
    Russ,
    I was 11 years old in 1969, and didn't move to Regina until 1975. Never heard of that name.
    Russ Kemp
    Jan 2008
    242
    Russ I did open the file with 2.24 you need to update.
